Beosound 9000
Stagg81
Posts 3
Stagg81 Posted: Sun, Sep 24 2017 12:02 PM
Greetings !
I removed the control panel on my beosound 9000 which is sited upright in a desktop stand. I replaced afterwards having got the serial number, but now the digital readout of cd volume etc is upside down, how do I re adjust ? Any ideas ?
Weebyx
Denmark
Posts 1,213
Weebyx replied on Sun, Sep 24 2017 12:52 PM
Make sure the panel is correctly seated, if it is not correct in place, the display will be in std mode.
the display will adjust according to how the control panel is located, so also make sure it is put in correct, it can be turned both ways.
/Jacob
Stagg81
Posts 3
Stagg81 replied on Sun, Sep 24 2017 1:04 PM
Thankyou for replying, I have removed it twice and replaced, no change. I have moved it whilst in situ without and difference.
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sun, Sep 24 2017 2:14 PM
The text on the BeoSound 9000 is orientated the same way as the keys on the control pad. If you remove the keypad and replace it "upside down" the text will also invert.
The display was designed to work this way to accommodate the numerous placement options of the BeoSound 9000.
Opman
Page 1 of 1 (4 items) | RSS
