Ok y'all I really need help,
I have a Beomaster 2400 and Beogram 3404 and listen to it everyday but two days ago I woke and got up and pressed play and noticed only the left speakers was playing. I adjusted the balance all the way to the right and only got miner music out of the right speakers. I pressed the pause button and right as the arm lifted, just for a second, music came from the speaker as it should. the same happened when I pressed the start button.. just as the needle touched the record, again just for a second, it played through both speakers as it should but as soon as the start arrow light goes out, which only stays on for a second as it should, the right speaker goes out. The radio plays fine with no problems ... CAN Y'ALL PLEASE HELP ME???
Bad muting switch or related mech. in the Beogram
Maritn
Do I replace it or repair it?
I'm not sure where it is or what it looks like. I have the bottom off but not sure..
