Replacement screw for Beovox S45-2 speaker stands?
PhilDevoid
Posts 8
PhilDevoid Posted: Tue, Sep 10 2013 4:25 PM
I was ready to raise my speakers on the stands but then realized that the 4 screws (two in each speaker)  that go into the speakers from the stand are missing.  I am most certain I can just go to lowes or some other hardware store and get something to replace it.
Any recommendations or fantastic suggestions as replacements at a low cost?  Dimensions and pictures please if you have them!
thanks!
Søren Mexico
Mexico City
Posts 6,411
If you only need the screws its Allen M5x40, thats an inner hexagonal metric threaded screw 5 mm diameter and 40 mm long. Do you have the washers and bushings ?
PhilDevoid
Posts 8
Thanks for this info!!!   :-)  I do not have the washer nor bushings though.
Søren Mexico
Mexico City
Posts 6,411
You will have to measure the holes in the stand the bushings has to be 1-2 mm smaller OD, and some 2 mm longer than the holes are deep, the speaker will pivot around the bushings. Looks like this: 4 is a finger nut, a normal hexnut will do, 5 is an Allen M5x50
PhilDevoid
Posts 8
Looks like I need 6, 7, 1 and 2.  I can just get away with the first mentioned Allen M5x40 and maybe some accompanying washer, yes?  I am not as concerned with looks as it actually holding them up properly and securely.
Thanks for these schematics too!!!
Phil
Page 1 of 1 (5 items) | RSS
