Suddenly dead LC2. Any hints?
This post has 3 Replies | 0 Followers
Hiort
Sweden
Posts 2,895
Hiort Posted: Mon, Sep 16 2013 8:25 AM
I placed a new bulb in a lamp that has been operated by a LC2. The bulb immediately "popped" with a flash of light and went dead. And so did the LC2. I have checked the fuse, but cannot see that it is broken.
I assume that its evident when the fuse has blown, right? Or can they blow and it is not visible to the eye?
And if its not the fuse, is there anything else I should check?
(The bulb was one of those energy saving bulbs that is replacing ordinary bulbs)
/Claes
mr_anders_son
sweden
Posts 1,710
LC2 can not handle energy bulbs I think!!?
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
beojeff
USA
Posts 2,012
beojeff replied on Mon, Sep 16 2013 9:51 PM
The new energy efficient bulbs cannot work with standard dimmers. They need special dimmers.
My solution was to just replace everything with the new Philips Hue bulbs that can be controlled to dim and change color using an iOS device. This took light control to an all new dimension!
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Sep 17 2013 12:40 PM
If the fuse is intact, are there anything else I can do?
I´ve tried with a regular lamp and it is not working, and the fuse looks okay.
/C
Page 1 of 1 (4 items) | RSS
