BeoSystem4 and MLGW
This post has 15 Replies | 3 Followers
epkgael
Posts 22
epkgael Posted: Sat, Sep 7 2013 8:23 PM
I recently swapped my BeoSystem 3 for a BS 4 and the only thing that I can't get to work is the Network Link connection to my MLGW. Anybody who has got the same setup or any pointers to what is needed in order to get it to work?
I like to use the phone as remote :)
Strangely some operations work so they are aware of each other, or at least BS4 is listening to the signals that MLGW sends out.
Anybody with BV11 might have some clue, since I guess there would be some similarities to BS4?
Any help appreciated!
/G
PhilLondon
London
Posts 3,637
In theory the BS4 and the MLGW should be connected with the NL (Ethernet) cable, not the ML (Masterlink cable).
Also have you got a NL/ML adapter in your setup?
Have you updated the MLGW software?
Beoworld app with direct photo upload and emoticons.
TripEnglish
Posts 1,639
The MLGW is now a native NetLink product. Unless there's an ML audio system you want to share on the network you don't need a NL/ML Converter.
That being said, you have to address it in the MLGW and set up your sources. It should work fine after that.
TripEnglish
Posts 1,639
Sorry - duplicate post
jowus
Posts 161
jowus replied on Sun, Sep 8 2013 1:12 AM
Why would you swipe BeoSystem 3 for 4? I thought the System 3 has more to do than the 4. Anyway, just curious.
mjmedlo
Posts 922
mjmedlo replied on Sun, Sep 8 2013 2:38 PM
I understand the sound processing is much more advanced in the 4.
Can you confirm?
I sit in the same position. I have a bv4-65 connected to a system 3 and am curious about the benefits.
Everything else in my system is ML do I would still have an ML system with a bs4.
Wondering if it's worth the hassle.
Millemissen
Flensborg, Denmark
Posts 14,680
Hi mjmedio,
you will need the NL/ML Converter for connecting the BSys4 to your existing ML setup.
Greetings Millemissen
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sun, Sep 8 2013 4:14 PM
Millemissen:
Hi mjmedio,
I don`t think so.
Agree with Trip.
MLGW with sw 2.10a can detect/control NL products without an NL/ML converter.
You just have to program your MLGW.
My dealer confirmed this. He has such a setup in his house.
Stefan
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Stefan,
and how would he get the ML-sound to his speakers connected to the BSys4?
mM
epkgael
Posts 22
epkgael replied on Sun, Sep 8 2013 7:46 PM
Thanks for your suggestions guys, but I already have updated the mlgw software to 2.10 and I have tried to configure the BS4 in mlgw setup (and removed all my previous configurations regarding ML.
I have a BeoSound 4 as well, but I'm thinking of getting rid of that one since it is really seldom used. My thought is at least to first get the new BeoSystem4 up and running with MLGW and then take a decision whether to connect the old ML-units or sell them. I have BeoPort also and some link system I can't remember the name of :)
Anyhow, I have made my own software program in Java that communicates with the MLGW and controls everything. That said, I therefore don't need the other ML-units in my setup and probably won't get a NL/ML-converter. I still think one needs it even though you have MLGW. I thought I would give it a go when I have BS4 + MLGW up and running to see how integration works. I post my findings!
As to the question why I swapped the BS3 for BS4 was that I like the idea of online PUC and software updates. Furthermore I'm curious about the new NL-protocol and what they will do with it. And I like the Rj45 ethernet cabling for everything :)
The transition was quite smooth. New cabling to my BV12-65 (3 x Cat7 Ethernet cables) and then 5 speaker adapters Rj45 to Din - your dealer has them. So some cable swapping and I was good to go. Left is to let a B&O technician come to my home and measure the TV for optimal configuration - new with the BeoSystem 4 I think.
My first impression is that there are many more options than BS3 - multiple sound settings and picture settings. A lot of other stuff in it too of course, such as Smart TV and compatibility with their remote app for iPad.
However I can't let go of the feeling that BS3 actually delivered better picture, at least for television with non-HD content.
BUT, still, I haven't solved the MLGW-issue :(
Any further suggestions?
Anybody knows what to enter in the SN-field of MLGW  for NetLink products? I put in the serial number...
Thanks again, hope I answered all the questions!
epkgael
Posts 22
epkgael replied on Thu, Sep 12 2013 8:36 PM
Well, finally working. Gathered some energy to make a new attempt and after a switch of MLN and a reboot of MLGW it suddenly works. Probably the reboot that was needed...
Well, thanks guys for all assist!
jvdl
Netherlands
Posts 129
jvdl replied on Fri, Sep 13 2013 10:24 AM
Is there anyone who know's the going price for the BeoSystem 4.........
epkgael
Posts 22
epkgael replied on Fri, Sep 13 2013 11:14 AM
I guess used items are hard to find, but retail price is ~33000 swedish kronors, which would be about 3800 €.
jowus
Posts 161
jowus replied on Sat, Sep 14 2013 3:21 AM
One store gave me a price of $4500 and another store said it will be around $5600. So I guess, we've to wait and see. It will be in stores next month. My problem is the back has just a limited connection to it, and I wonder how I can connect all my stuffs to it.
BeoMegaMan
Posts 601
In the US it sells for $4,595
Ah, you know... A little B&O here, a little there
jowus
Posts 161
jowus replied on Mon, Sep 16 2013 12:15 AM
The Price sounds good though, but I'm not too sure, if is going hold up to BeoSystem 3.
Page 1 of 1 (16 items) | RSS
