While working on this unit and I was glueing on the frame were the main screws that secure the face to the body. I got super glue on the smoked plastic front panel. I sanded up to 4000 grit sandpaper and buffed it with plastic polish. I still have a small area that is cloudy. Any suggestion on how to fix it?
You could try t-cut (car polish) I have used on various decks and has worked, but it may be just as your plastic polish
Hope this helps
Ta
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
