When my Beolink 700 is on the charger, it keeps waking up every few seconds, for a few seconds, then goes to sleep again...
Have you had the issue? How can it be fixed? Is it just the case of changing the battery pack?
Beoworld app with direct photo upload and emoticons.
Yes. You are right. I had the same issue with one of my BL7000s years ago.
Changing the battery pack solved the problem.
Stefan
Thanks Stefan!
If I remember well, there's a trick to use normal batteries instead of the pack, isn't it?
P.
Yes. I remember that too.
Searching in the old forum might help.
But I`m sure you have to use five rechargable batteries and solder them to a pack.
Someone is usually selling them on eBay - e.g. here.
Thanks.
I actually just ordered this one.
Experiences have proven that only NiCd batteries with same capacity as the original will work well.
If you use NiMh batteries with higher capacity the will be useless in a couple of month.
//Bo.A long list...
Lots of posts on the old forum about NiMh being the wrong choice - e.g. here.
A new battery pack will fix your problem Phil.
Too long to list....
Thanks, all, I'll let you know how things go when I have received the battery pack...
PhilLondon: Thanks, all, I'll let you know how things go when I have received the battery pack...
Good luck, but I'm sure your problems will be gonerz.
