I just acquired beomedia 1 and I wonder if there is any use for me.I have BeoSystem 1 setup with BS9000 plus BL3500 in linked room. How can I use beomedia?Any recommendations are appreciated.
BeoSystem 3BeoSound 9000BeoLab 8000/6000/4000/3500/BL2PlayMakerBeoCenter 9300BeoGram 5500BeoCom1/1600 + BeoTalk 1200BeoCord vx5500
You can use it to bring in Net Radio and Net Music. Some of my clients in the past have also used it as a NAS without having it on the ML System at all. It can be recycled in different ways.
Ah, you know... A little B&O here, a little there
Don't forget to change the screen settings in the BM1. Looks better in combination with the BS3.
BM1 will automatically be set to AV5 (PC) if you use the VGA and ML socket.
Actually just got BeoSystem 3 so will be connection it to BeoMedia 1.Any Idea how much pre-owned BeoMedia 1 may cost?
