Earset 1 repair?
danezro
Posts 106
danezro Posted: Mon, Mar 11 2013 4:23 PM
Can anyone tell me if it is possible to repair an Earset 1 at home? The cable connection into the earpiece is very loose which means that it either doesn't work or if I mess around with it I can get a crackly sound but not good enough to hold a conversation.  The arrow in the  picture below shows where the cable is loose....
Dan
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Mar 11 2013 5:06 PM
Pretty sure that the advised repair route is to replace Sad
However nothing to lose trying to take it apart - but at a guess it will not be made to take apart.
Peter
danezro
Posts 106
danezro replied on Mon, Mar 11 2013 5:18 PM
Thanks Peter,
There is no obvious way of taking it apart - I wonder if anyone has tried before or if there is a tech guide or something?
Dan
GLeirer
Germany
Posts 1
GLeirer replied on Sun, Sep 29 2013 10:20 AM
Dear Dan,
Did you get it fixed?
I've got a similar Problem: My Beocom4 recently does not recognise the Earset, so I don't know now whether the Handset ist not in order or the Earset ist damaged.Sad
I'd need at least the pinning / tech doc for the Earset to test this (unfortunately nobody around - even the B&O retailers have an beocom 4 working, so I was not able to test this out)Angry
Maybe you cold tell me the pin assignment and / or el. Characteristics of the Earset?
Many Thanks in advance
Gerhard
Page 1 of 1 (4 items) | RSS
