I have been using my Beovision 10-40 with Front & rear speakers. Today the rear speaker have stopped working - red light remains on. I have checked the cable, and the settings in sound/adjustment, and have it set for Video speaker option 5.
Are there any other settings that could of changed, or is there a full reset option?
Thanks Peter, I had already tried this and disconnecting the ML from other devices. Still have the same problem.
Just an idea (I don't have a pure B&O 5.1 Setup):
Did you watch a movie with 5.1 material?Did you try Speaker 4 for Sound / Music (via ML as well)?
Ralf
I have tried both. It used to work, that whenever any source switched on, the 4 speakers would activate. Currently is as if the rear speakers are disconnected.
