BEOVISION AVANT Volume control
webwerk
Posts 2
webwerk Posted: Wed, Aug 3 2016 7:58 AM
Hello,
I own an old BEOVISION AVANT and my remote control is not working anymore.
(http://www.muellerleipzig.de/Download/3508009-D-Beov-Avant-99UG.pdf)
At the back of the TV are some buttons:
  1. EJECT
  2. REWIND
  3. V.TAPE
  4. SAT
  5. TV
  6. Play Timer
But there is no volume control? Is there any button combination to change the volume without remote control? A new B&O remote control would cost more than the value of the TV. I did buy a RM-Series ™ Remote B&O BEOVISIONMX2000 but it does not work.
Any help would be appreciated.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Aug 3 2016 8:29 AM
If you use the TV daily, then a second hand Beo4 or Beolink 1000 should not cost a lot ?
What remote do you have now, and how is it not working ?
/Weebyx
BeoIce
Recklinghausen, Germany
Posts 751
BeoIce replied on Wed, Aug 3 2016 9:09 AM
If you want it really cheap, this one would be something for you.
I would prefer a second hand bl1000. You can get them often for under 50€. It's a real bang & olufsen remote and no plastic trash.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Wed, Aug 3 2016 10:28 AM
@ Beolce
I second that motion...
The BL1000 pretty much does everything you ask it to. Smile
No need for hidden menus, and it uses far fewer clicks, and you can use it without even looking at the remote!
The AV terminal was by far the best one, since it had both the SHIFT & the CTRL function!
webwerk
Posts 2
webwerk replied on Wed, Aug 3 2016 11:11 AM
Hi Martin,
my remote looks like this: http://www.ebay.de/itm/B-O-Bang-Olufsen-Beo4-Beo-4-Fernbedienung-mit-DVD-Taste-/282099006017?hash=item41ae693a41:g:7ysAAOSwAvJXC3g9
Would the  bl1000 work with my TV?
Thank you ...
BeoIce
Posts 751
BeoIce replied on Wed, Aug 3 2016 11:52 AM
It will work, but the buttons are named different.
TV=TV
SAT=DTV
V.TAPE=V.MEM
DVD=SHIFT+SAT
etc.
DISCODUCK
Posts 14
DISCODUCK replied on Tue, Mar 27 2018 1:38 PM
Hi Guys.Quick question on this topic.Does the Beolink 1000 remote work with the Avant range of tv's without losing any functionality?
Thanks,
Discoduck
Page 1 of 1 (7 items) | RSS
