Hi Keith, I just got an access denied while trying to reply to CHARTZ!
That was seconds after replying to another post.
Eddie
Eddie,
What happens if you reply to him a second time ?
Regards Keith....
Give me 2 mins...
It only happen's on the Beolab 5000 post, I can not reply to any on on it. Same message come's up access denied.
Can you try again please, I think I have found the core issue here
I just sent a reply and I do not see it coming up....
It works no problem now, thanks for all your work on the New (order) Forum.
Regards
I can see it. Posted at 18:51 GMT
If you think nobody cares, try missing a couple of payments.
Stonk:I can see it. Posted at 18:51 GMT
I have only had 1 beer and I can not see it, i am putting this gremlin down to Chartz, :-)
That's one beer ahead of me. I'm off to do catch-up
Stonk:I'm off to do catch-up
I am off with a second one to give the avant some air time.
I believe that all the "Access Denied" errors a few members have been getting are now resolved.
Also, the issue that Mexking had with folders related to two issues as follows:-
valve1: Hi Keith, I just got an access denied while trying to reply to CHARTZ! That was seconds after replying to another post. Eddie
Could reply no problem
