Hi there,
I picked up a beovision 3 for next to nothing and when i hooked it up the led comes on for standby and whenever i press buttons on my beo4 the tv doesn't respond.
I've tried switching the power button on and off on the front right and connecting and disconnecting from mains but it hasn't made any difference.
Your help would be much appreciated
Thanks in advance!
maybe it's set to Option '0' or to one of the Link-Options.
Try the option setting for the TV. set it to '2' which is the default.
Complete description of Option setting can be found here.
RaMaBo
Ralph-Marcus
RaMaBo: Hi, maybe it's set to Option '0' or to one of the Link-Options. Try the option setting for the TV. set it to '2' which is the default. Complete description of Option setting can be found here. RaMaBo
Ok when i set it to option 2 the led blinked once and that was it, when i change the option it blinks once too, but neither tv/sat/dvd works when i press them on the remote, but they are fine on my avant.
Any other ideas?
