I have a fully functioning Beocenter 7700. Unfortunately the cartridge and stylus are missing from the turntable. (they got lost in a move years ago). I cannot afford to replace them right now and wanted to know if there is a way to hook up an external turntable to the system.
Thanks!
p.s. if anyone has any ideas as to where to purchase a new cartridge for a reasonable price, I would love to know!
Cartridge here, I dont know if the Beocenter 7000 has any connectors for TTs or Tape, someone who knows will chime in.
Welcome to the forum
Just checked, there should be a tape input. You will probably need a preamplifier (depending on the TT, you want to connect) you will also need a RCA to 5pin DIN converter cable, from the preamp to the tape input. I´m not 100 % sure of this, so wait for more answers
