Beolab 4 pc speakers
Mdjolly1973
Posts 51
Mdjolly1973 Posted: Mon, Oct 21 2013 5:45 PM
Hi all,i have a 26" beovision 8 tv running a pair of beolab 4 powerlink speakers at the front,i have acquired another pair of beolab 4's for the rear BUT the PC version,
My question is:
can i run the standard lab 4's via powerlink and the pc's via the headphone socket and achieve an acceptable sound?
I have tried the pc's via the conversion leads but don't work but do via the headphone connection...
Confused.com
Cheers
Mark
elephant
AU
Posts 8,219
elephant replied on Mon, Oct 21 2013 9:54 PM
I would expect using the headphone to suppress the main speakers ... Not sure what the alternative cable issue might be.
Are you trying to create a surround sound setup ?
BeoNut since '75
Mdjolly1973
Posts 51
Thats the ironic thing,when the lab 4 pc speakers are connected via the headphone jack it does not suppress the sound on the other 'powerlink' connected lab 4 speakers...
If im not losing any sound quality this may do for me....
AdiS
Posts 170
AdiS replied on Mon, Oct 21 2013 10:15 PM
Mark, there are special cables for using Beolab 4 PC with Powerlink. Similar to this one: http://picture.yatego.com/images/503f7d37882402.5/f4d8c3625af3ea03fc2e09198eb9ff5d-kqh/-vivanco-adapter-kabel-5-pol-din-stecker--3-5mm-klinke-klinken-stecker-din-5pol-.jpg
 Search for it in the forum - there is a thread with this problem!
regards, Adrian
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Mdjolly1973:
You're hooking them up the way they're designed to be hooked up, only instead of a computer you're using a TV.  Not sure why you think you'd be losing sound quality.
Mdjolly1973
Posts 51
It is the sound already connected on the other pair of beolab 4 speakers which are connected and still work via powerlink while the pc speakers are connected via headphone socket i was more concerned about....?
Page 1 of 1 (6 items) | RSS
