Hello!
I have a lot of ghosting (seeing dobble shadows) on my tv in 3D, my friend has a 65" Samsung plasma has almost nothing of this problem. Is this a common problem on this tv?
Beovision 7-55" 3D, Beosound 5, Beolab 9, Beolab 8000, Beovision 6, Beo 6, Beoremote one, H8, H2.
Only expensive ones.
LCD vs Plasma.
And the winner is...Plasma
Screen/monitor temperature is very important for 3D TV, which is based on LCD technology. This is because the LCD material response becomes faster when the screen/monitor reach higher temperatures. Ghosting is most visible when the screen is cold, and therefore depends on how long the TV has been turned on before you start to see 3D TV. When the TV is turned on for about an hour, the LCD screen has reached the final operating temperature, and ghosting is at the lowest level.
Hi !
I am also very disappointed by the 3D function of the beovision 7 55. Much brightness and contrast but awfull ghosting and other problems I cannot exactly define but a general impression of gadget rather than anything else.
I tried Prometheus and Hugo Cabret 3D versions on other configurations (not B&O) and it was perfect. The problem doesn't come from the BR player because it's the same with 3D films on the cable.
My impression is that it commes from the glasses but i'm maybe wrong
It's the first time I read someone seems to realize that 3D is not good with that so expensive TV
Beobuddy: LCD vs Plasma. And the winner is...Plasma
Yup. IMHO hands down! Still mad I sold my BV5.
Too long to list....
Hi MartinW
Happy to learn there is a solution to this issue. The TV I bought was indeed in the shop since a very longtime because sailor tried to sell a 2D modell (exposition's modell). So I hope that you're right and that the technician has omitted to make the update. Is it also important to make the software update of the BR player ?
Do you know the reference of your software ?
Thx for answer
Sorry to disagree Martinw, , but after software update by technician, the same problem did remain. I agree with BEOCET who said that the image becomes better after one hour (I would say after half an hour) but it's still not perfect.
Still have to do a software update of the BR player (download is interrupted each time i have tried with the mesage "error during download)" but problem occurs also on VOD, so few hope that update succeeds to solve this issue.
strange that so few poeple complain about that
I have since beginning noticed the ghosting effect in 3D. When the Tv has been on about one hour, then you reach the maximum performance of the screen and therfore minimum of ghosting, but it is still there!
The BV 7-55 3D suffer also from another problem: CLOUDING EFFECT in 3D-mode. I have had my TV changed 4 times because of this, but still a lot of clouding effect in 3D-mode. In 2D-mode the picture is perfect but 3D is not so very good for the price-tag of the TV.
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Hi
I do agree with you Martin. Meanwhile recent software update ( SW13.12a for AP and SW23.00a for IOP like mentioned above), still need one hour for the optimal performance : 3D films are then very well watchable (still not perfect), but is it normal to wait one hour to can watch a film ?
In my experience, you must also wait in 3D mode and not 2D. So it doesn't help to watch another program on TV before the 3D film. You have to launch the 3D film, quit the room, come back after one hour et then watch your 3D film in good conditions (not perfect but good)
I also noticed persistant clouding in 3D
Since the last blu ray update, blu ray player restart sometimes from the beginning and not from the point where I stopped watching (it depends on the type of blu ray disc)
Griebel: Well, since there are no reviews of the 3D filming of the BRD we buy, it´s just a matter of luck to get the pearl or not!
I find lots of reviews for 3D's here:
http://www.blu-ray.com/movies/search.php?search=reviews&&other_bluray3d=on&submit=Search&action=search
Thanks fort the link. Much helpful... and now I can understand why the 3D movie was not good: "Iron Man 3 simply isn't built to be a 3D spectacle" Why the hell did they actually release the 3D BRD if it's non-watchable!?
