I have realized that many Beovox is 4 ohms.
Considering that multirrom with two pairs of speakers were a part of the B&O concept, with Beovox.
Running two pairs of speaker that is both 4 ohm, is a tremedneously load for the amp.
Was this something that was considered in the design of the amps that they could by default handle any 2 pair of Beovox people had at home ?
Maybe strange narrow question, but maybe somebody knows.
My re-capped M75 are my precious diamonds.
The impedance varies according to frequency etc.
Generally, if your Beomaster has connections for four speakers you can safely connect four Beovox speakers.
