Beolab Penta 1 speakers
Gary25
Posts 2
Gary25 Posted: Fri, Nov 15 2013 12:33 AM
I've just joined this forum and hope that this is in the correct place.
I live in Canada and I have just been given a set of Beolab Penta 1 speakers and a Beomaster 5500.
I would like to know if I can use these speakers with a system other than the Beomaster 5500.
If I can could someone please explain to me how I connect these.
Thanks very much for any and all assistance.
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Nov 15 2013 9:30 AM
Hello Gary, welcome do the Forum.
What System do you have in mind?
As you can see, lots of possibilities...
Ralf
PS: Edited due to cut-off picture in first attempt...
Gary25
Posts 2
Gary25 replied on Fri, Nov 15 2013 12:28 PM
Thanks so much for answering my cry for help. Im confused.
On my din connector at the bottom of the amp I have 2 wires coming out of the din connector, each with a sheild.  I have a white wire with a sheid and a red wire with a sheild. Please explain again.
Will I be able to plug In the speakers and use their power amps if I run these through another system
Sorry for all the questions but I want to make sure I dont do anything wrong and destroy these.
Honestly im not nuts. I've never used this kind of equipment before. My main equipment is a Techniqes flat serries with a set of Altec m5's and 18" subs with Ramsa crossovers.
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Nov 15 2013 12:45 PM
The sockets for DIN + springs are for regular connection of normal (shielded) loudspeaker cables, you won't be using the amps of the speaker then (in my understanding - since you already Transfer an amplified Signal).
To use the built in amp, you need the line-inputs, attaching these to the pre-outs of your amp/reciever (if these are availabe / an pre-amp can be used as well).
Ralf
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Nov 15 2013 1:43 PM
kallasr:
That´s not correct. All inputs will use the built-in amp. However the speaker leve input terminals will reduce the level to be appropriate for the amplifier.
If you want to use them as passive speakers the amp can be removed.
//Bo.
A long list...
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Nov 15 2013 2:14 PM
Thanks for explaining/clarifying.
Ralf
Page 1 of 1 (6 items) | RSS
