Earset 2 question
This post has 2 Replies | 2 Followers
chris
Posts 79
chris Posted: Fri, Nov 8 2013 2:41 PM
The battery in my earset 2 is dead. Is it difficult for it to be replaced?
I tried opening it myself by unscrewing the small screw on the bottom but nothing happened.
w5bno123
London
Posts 578
w5bno123 replied on Sun, Nov 10 2013 9:08 PM
Hi Chris
It is not possible to open the casing to access the battery without causing damage. When under warranty the Earset would have been swapped over. I am not sure what the service possibilities are today. A call to your local dealer would be my best advice.
chris
Posts 79
chris replied on Sun, Nov 10 2013 9:45 PM
I opened it myself today and removed the battery
i made a tiny crack but it's not noticeable
i don't know if I should fix it now or not
i need to find a new battery that's all
Page 1 of 1 (3 items) | RSS
