Does anybody know how to remove the front grill from a pair of beovox 901?i rather ask first before i break them.
Thanks,
Aymeric
Yes, this is pretty tricky job. I am not sure if it is the best way but I managed this problem once sliding / shifting one of the rubber frame to the side (from up) and begging from one corner pulling the metal front out. I hope you understood my explanation and now know how to do
good luck
Vintage Bang & Olufsen
Carefully ease one of the frame pieces (f.e. the top one) free from the wooden cabinet.Do the same a couple of inches down both sides to assist it and then slide the metal grill upwards and off.
