Subwoofer connection / wiring of powerlink cable
This post has 3 Replies | 2 Followers
BozoQed
Posts 3
BozoQed Posted: Wed, Nov 27 2013 10:43 AM
Hi all,
I was wondering, is it possible to send a stereo SUB signal to B&O active subwoofers using  a powerlink cable, whilst using both channels (so without omitting / discarding one channel)?
In other words are they able to perform the R+L inside the speaker?
If only one channel on the powerlink cable is actively receiving, which pin would that be (left or right channel)? I know that normally one pin is sub and the other center...
Kind regards,
Robert.
Geoff Martin
Struer, Denmark
Posts 672
Both the BeoLab 11 and the BeoLab 2 take the PowerLink input, sum the left and right channels and send the result to the filter-amplifcation-driver(s). They cannot be put in a mode where they use only one of the two channels on the PowerLink cable.
You can choose to put the BeoLab 19 in this mode using its L / R / L+R switch.
Cheers
-geoff
BozoQed
Posts 3
BozoQed replied on Wed, Nov 27 2013 11:25 PM
Hi Geoff,
Thanks for the info. Do you (or anybody else) by any chance know how a powerlink cable with combined center / sub signals is wired.
Is center - left / right, same sub - left/right?
Thanks in advance.
Cheers,
Robert.
BozoQed
Posts 3
BozoQed replied on Wed, Nov 27 2013 11:51 PM
I made a mistake I mean sub / Center on RJ45 standard...
Page 1 of 1 (4 items) | RSS
