Hi all,
If some of you had already the chance to compare both versions of BV7-32 mk2 and mk3 with the notified spec difference related is a ratio of 1200:1 over 3000:1, thanks to share your experience.
I would like to purchase a BV7-32 and the mk3 is of course more expensive dut to that and would like to know if this is really visible (in same conditions of use).
To me the figures are important but what matters to me is the overall impression, here the image rendering. Like for speakers it can be pleasent for someone not for others, there are rooms dependant etc... but sometimes some differences are really visible this is what I tried to find on the net, but without responses but only pure technicals specs...
Thanks to all and have a merry Christmas !
Franck
