Does anyone know the colours in the din plug on a Beogram 6500
This post has 5 Replies | 0 Followers
cmsammy
Posts 84
cmsammy Posted: Mon, Dec 30 2013 6:50 PM
I have a Beogram 6500 which has been changed to phono plugs and I want to put the original 7 pin din plug back on it. I have the left and right channels back OK but the data wire appears to be wrong. I have connected the yellow to pin 7 but all I get is a buzz in the speaker each time the deck does something, i.e. the tone arm lifts, but the deck does not respond to any commands from the control panel.
elephant
AU
Posts 8,219
elephant replied on Mon, Dec 30 2013 8:31 PM
Check the wiring diagrams on beotech
BeoNut since '75
cmsammy
Posts 84
cmsammy replied on Mon, Dec 30 2013 8:37 PM
beotech.com is a chinese consulting web site ???
elephant
AU
Posts 8,219
elephant replied on Mon, Dec 30 2013 11:39 PM
Apologies - it is a beoworld micro site - here is the correct link, copied and pasted from the browser instead of my memory !
http://www.beoworld.org/beotech/index.htm
BeoNut since '75
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
elephant:
Beotech is actually not very helpful as it does not include the wiring of the plug from a turntable.
Regards Graham
cmsammy
Posts 84
cmsammy replied on Thu, Jan 2 2014 9:05 PM
Worked it out by trial and error.
Black to pin 2          (left and right channel earth)
large White pin 3   (Left channel +ve)
large Red pin 5     (Right channel +ve)
Yellow pin 7           (Data)
Shielding around Red and White to plug case
Everything works a treat
Page 1 of 1 (6 items) | RSS
