I have a Beocom 2 phone and I really want to change the color from the dull grey to one of the new glossy colors. I called B&O service and was told that it's not possible or allowed to do this. I asked why and was told that for the phone to be taken apart it must be sent to denmark to be taken apart with a special machine. I don't see why this isn't possible. I really want to change the color...is there someone here who can confirm that this is not possible?
Unfortunately, I think your dealer is correct. Why not sell yours and buy a new one - you will probably find that the difference in cost between getting yours changed and this will be much the same!
Peter
When you see how tricky it is to just replace the battery door after a battery exchange, you can easily understand that it's almost impossible to open everything to replace the shell...
diisign.com
