Are these motors part no MMX-5D2RSB on sale anywhere? or has anyone been able to repair these motors? It seems a very common fault, bearing failure. I have two motors with the same fault. Any help appreciated.
John.
Will the motors run (albeit noisy) ?Which belts were used ?
(Wanted ads MUST be placed in the Private wanted forum section).
Hi Martin, I bought 2 sets of belts over a year since off the internet, Can not remember who from. one set has been in regular use working ok for a year. Of the other two sets one would not start the other had to be spun-start and sounded very rough with no power. Test were with no belt fitted and run from a new 9v battery "wires disconnected from Hall sensor" I dismantled one motor and the contacts in the bottom of the motor were burnt up. To be clear I have 3 Beocenters 1 perfect 2 with faulty tape decks and would like to get a second one working.
