Hi
is it possible to up date my Beovision7 mk2 to either the latest version or at least to mk3. Or if my television is a mk3 would it be possible to up date it to the latest version.
If the above cant be achieved will i have to purchase a new television.
You can't 'make' a MK3 out of a MK2 - different 'machines'.
But you can (software) update both.
The MK3 gets improved from the updates, but won't get any BluRayplayer or 3D functionallity that way.
What are your wishes for 'your' tv?
Thanks for your response. I know i wont get any Blue Ray or 3D functtionallity i just want to update the television to get all the other changes that go along with the update. How can i go about this in particular i would like to try and network the television with my home network to enable me to use the ipad app.
pbarnes3: Thanks for your response. I know i wont get any Blue Ray or 3D functtionallity i just want to update the television to get all the other changes that go along with the update. How can i go about this in particular i would like to try and network the television with my home network to enable me to use the ipad app.
The iPad app won't work with any TV older than a year or so - BV11, V1, BV12 etc. it won't even control my Jan 2013 BV10-32.
I'm afraid you can't upgrade a MKII BV7 to anything without swapping the entire TV. The MKII doesn't even include the BS3-based chassis.
Might be worth thinking about upgrading the TV?
