Hi all,
is there anybody who wants to sell a RIAA for a Beogram? Unfortunately my 9500 has no RIAA but I need it to connect the BG to my Overture. At the present I have a noname pre-amp in the BG 9500
Thanks Tabloka
You should be able to use any RIAA amp avaliable in audiostores, just make sure you by a RCA- Din adapter för the B&O.You can get a nice one for 70-80 Euros.NAD for instance makes cheap good RIAAs Where do you live?, people living in the same country as you, that fiddle around here might give you local tips
My re-capped M75 are my precious diamonds.
//Bo.A long list...
Do a keyword search in the Beoworld forums for 'phonopreamps' (one word). You'll find the source to buy them, and specific model recommendations from members.
