Spotify support on Beo 5/6
This post has 28 Replies | 3 Followers
rmclachlan
Posts 79
rmclachlan Posted: Mon, Jan 13 2014 6:30 PM
Is there any sign of Spotify support for the Beo 5/6 especially the Beo 6. Album Covers + Track name, ability assign to favourites/starred etc?
ECF
Malmö - Sweden
Posts 35
ECF replied on Mon, Jan 13 2014 7:11 PM
Hey
Please write B&O support and ask. This will put some pressure on them!
//Erik
rmclachlan
Posts 79
I have just done that.
gysse2004
Hellerup
Posts 192
gysse2004 replied on Mon, Jan 13 2014 9:56 PM
Please report back about this- would be great!!
Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
PapaJustify
Posts 110
There is no support planned, sorry.
rmclachlan
Posts 79
If that is the case then they are undervaluing their own products. If they can already do this with the BS5/BM5 content, I cannot see it being a huge jump to add spotify support, in fact it is this kind of development that would underpin their product offering. This is a software issue, no hardware required other than that which they already have.
Are they planning a new controller with this ability?
PapaJustify
Posts 110
It also requires a bit of different hardware that can run that kind of software that is required. Also Spotify has to play along to allow this functionality.
rmclachlan
Posts 79
What extra hardware is required? Surely the BM5 is doing this already to deliver the album covers to the BS5 & Beo6 in n.music mode, and the cover to the BS5 in Spotify mode. Yes, I can understand there may be something being witheld by Spotify that prevents this, although I cannot think of a good reason for this.
PapaJustify
Posts 110
Well, I know that specifically in the case of transmitting Spotify covers special agreements would have to be made with the copyright-holders of each label.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Wed, Jan 15 2014 4:38 PM
Spotify covers are already sent to BS5, BV11, V1 - should be no problem, regarding copyright, with Beo6...or do I miss something?
There is an ipad app called remoteless, that works as a Spotify remote installed on a PC. Maybe this will also with BM5?
Or maybe via Beolink app?
Stefan
tournedos
Finland
Posts 7,357
tournedos replied on Wed, Jan 15 2014 8:04 PM
stefan:
Not knowing anything about the actual problems or agreements... BV11 and V1 are the Spotify players, they are not transmitting anything anywhere when they show the artwork. Similarly with BS5 which cannot be used alone, you can consider it just a wired display for the actual player (because that's what it is) and not much different from the display screen of a desktop computer running a Spotify application.
--mika
rmclachlan
Posts 79
Surely the hand held sonos controller is not transmitting anything, it merely selects the music that the sonos box will stream, is this not analogous to the Beo6 controller?
stefan
Posts 2,920
stefan replied on Wed, Jan 15 2014 9:49 PM
tournedos:
stefan:
Right. But Beo6 will transmit same artwork for N.MUSIC, for the stoted music on HD, so should be possible for Spotify.
Beolink app also display cover from N.MUSIC....
Stefan
tournedos
Finland
Posts 7,357
tournedos replied on Wed, Jan 15 2014 9:59 PM
stefan:
That is irrelevant (to my point, which may be totally beside the point already, but anyway...). N.MUSIC artwork comes from the user's library on the HD. Spotify's artwork comes from Spotify while you play. We (or at least me) are not discussing a technical problem here, but what is allowed by Spotify and what is not.
--mika
PapaJustify
Posts 110
tournedos:
stefan:
Exactly.
rmclachlan
Posts 79
So is the problem actually a Spotify licensing issue or lack of software development by B&O?
Millemissen
Flensborg, Denmark
Posts 14,680
All this fuss over some tiny little coverpics on a minature display.
I would go for a 'BeoPad' instead.
rmclachlan
Posts 79
Mmm...
What is a "BeoPad"?
Millemissen
Flensborg, Denmark
Posts 14,680
Don't know - but it would be nice anyway Stick out tongue
Just kidding - what I meant was a mobile device with a bigger screen/display to select/control the media (local or from a music service) to be played through B&O speakers....and to show the coverpics as well.
Not existing, but maybe someday.....
stefan
Posts 2,920
stefan replied on Fri, Jan 17 2014 10:33 AM
PapaJustify:
tournedos:
stefan:
Exactly.
Not exactly. I had hoped that you could explain your post a bit further:
"Well, I know that specifically in the case of transmitting Spotify covers special agreements would have to be made with the copyright-holders of each label."
Obviously you can`t.
Usually Beo would make an agreement with Spotify. Spotify has agreements with music labels, artists, etc.
So,  if Beo made agreements with Spotify that exclude coverart sent by Beoremotes, this was a big mistake.
I can`t believe that. You, as a dealer, should know that....
So, please explain, what "exactly" is the problem?
Stefan
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Jan 17 2014 12:55 PM
I use SONOS at home.
Using the sonos ipad app, choosing spotify, you see all the artworks / covers...
Ralf
BeoMegaMan
Posts 601
BeoMegaMan replied on Fri, Jan 17 2014 12:57 PM
The problem is that Spotify sends the art to devices that are playback or sudo playback via connect. Beo6 isn't that device, merely a remote that speaks to your BM5 HDD. Besides that Beo6 is no were capable with its hardware to take in that task effectively. It can barely handle the cover art as it is now. There will be no more development of more features, only additions of control for new products and existing.
Ah, you know... A little B&O here, a little there
rmclachlan
Posts 79
The Beo6 has to receive the Album cover & title from the BM5. The B&O application on the BM5 has to extract and render that info from the HD for locally stored files & similarly render the Album artwork & title from Spotify onto the BS5. It sounds as though you are suggesting that Spotify is running as a separate application on the BM5 and is communicating directly with the BS5. If that is the case then I could believe that it would be impossible to display the artwork on the Beo6, if that is not the case then I cannot see any technical problem other than software development to rendering to the Beo6. At the end of the day if it can already be displayed on the BS5 then why can it not be displayed on the Beo6. Displaying the artwork on the Beo6 is the one of the primary functional advantages over the Beo5.
gysse2004
Hellerup
Posts 192
gysse2004 replied on Sun, Jan 19 2014 2:18 PM
@rmclachlan- now that is a valid point, let hope Struer is seeing this !
Peter
rmclachlan
Posts 79
I received a reply from BeoCare, no great surprise as to the content. Very polite and helpful but depressingly familiar...
Dear Mr xxx
Thank you for contacting Bang & Olufsen Customer Service. Please excuse the very late reply.
Unfortunately, we cannot say if or when we will be able to offer 2-way functionality between Beo6 and Spotify on BeoSound 5, or if or when it will become possible to use Beo6 to mark favourites/add to queue in Spotify.
We have forwarded your requests to the development department and will get back to you, should these features become available at some point.
Have a nice day.
Kind regards,
Customer Service
PapaJustify
Posts 110
stefan:
Stefan
Well, I could elaborate on it, but what does it help? Specific agreements would have to be made with Spotify. I assume that B&O didn't make these agreements or did not want to make these agreements for reasons that I touched upon initially: don't expect any big developments for Beo5/6 anymore.
rmclachlan
Posts 79
Please elaborate. It might not help but I am great believer in understanding a problem before accepting whether there is a solution or not.
Any insight on whether there will another controller to replace the Beo6? My view is that they really need one, and one that is considerably easier to program and can be prgrammed by the end user.
PapaJustify
Posts 110
rmclachlan:
Well, I cannot go into all the details, but there are several things in this that make 2-way support for Spotify on Beo6 a bad business case. First of all it is the licensing. Spotify wants to have money per device accessing their service for album covers etc. For such devices they normally request to have their own client on the device OR they have specific requirements towards branding and functionality. All things that would require money, development and are partly not feasible on the hardware.
Those people suggesting that you would just have to transmit covers from a device like BM5/BS5 I have to tell that Spotify does not allow this per se. New, very specific (expensive) agreements would have to be made and this normally does not go without any branding/functionality requests from Spotify as mentioned above.
So the big question for B&O would be: Is it really worth investing that much money into a device (Beo6) that is already beyond its best days?
I have no idea what is planned in terms of new remotes, but from what I understand the BeoRemote app is the way to go for them in the future.
rmclachlan
Posts 79
rmclachlan replied on Thu, Jan 23 2014 10:36 AM
OK, I think that is a fair reply. Hopefully B&O will be forthcoming with a better controller for their flagship audio product - no matter how it is done.
Page 1 of 1 (29 items) | RSS
