Can someone post an xml file for a loewe individual compose.
I purchased a beo5 for my beosound encore but i also have a loewe individual compose. Hopefully someone have it.
Thanks in advance.
Regards,
Edwin
Hi Edwin,
have a look at my files collection here
hfat
Thanks,
i will try try this out
Hfat,
I found this files already. I use them but i miss some buttons. For example the numbers. I like to make some logo's for tc stations and i need the codes 0,1,2,3,4,5,6,7,8,9. I also miss the button record.
Thanks for the files because most of the functions work!
Regards Edwin
The numbers are located on the numbers page (icon "+") as usual.
The record button should be on page 2, the middle on (Aufnahme, sorry not translated to english)
The aufnahme by me is not working. The numbers are working on the + button. But i would like to add a page with presets and therefore i need the commands for the numbers
I've added a third page with the number buttons, so they are also available in the 3rd-Party IR command list.
Which commands are not working for you?
Give me the list and I'll try to re-record them for you.
Hfat, Thanks, very nice of you!
I will try this out today and let you know.
At this moment i know that the record button (aufnahme was not responding) I need this to start a ayfnahme or plan a recording in the peg menu.
Thanks!!
It works. The only missing thing is that in the + screen (preset screen) and in the extra screen with the numbers the hard buttons not work (up, down, volume etcetera).
How can i make that work?
Thanks in advance
Hfat, It works.
The only thins what is missing is that in the + screen and in the extra screen the hard buttons not work (par up, wind, volume etc)
Can i make them work in the configurator?
I copy the buttons and it works great. So no need to rework the xml. Many thanks for helping me.
nevertheless just finished reworking the xml.
All hardkeys are working on all pages, including the fast wheel functions.
