Beosound 8 wireless?
This post has 11 Replies | 2 Followers
Des
North West, Engalnd
Posts 5
Des Posted: Sat, Jan 4 2014 7:41 PM
Can anybody tell me if there is any way that the BS8 [not A8] can be used wirelessly i.e. can I sit in my room and search, select and change tracks from my armchair with my iPhone5 or MacBook in the same way as I would be able to with the A8?
Thanks in advance,
Des
hfat
Vienna, Austria
Posts 663
hfat replied on Sat, Jan 4 2014 8:17 PM
You could connect a playmaker.
Just search the forum
hfat
moxxey
South West, UK
Posts 5,359
moxxey replied on Sat, Jan 4 2014 8:53 PM
Des:
Yeah, using Airfoil Speakers Touch: http://rogueamoeba.com/airfoil/ios/
This is an app for your iPhone/iPad/iPod Touch which enables you to stream content to your iPhone/iPad/Touch from another device, such as your MacBook or another iOS device. Basically, it sets up your BS8 as an AirPlay speaker.
I use this if I want to stream controllable content from my MacBook Pro.
Veermer
Murcia, Spain
Posts 49
Veermer replied on Sun, Jan 5 2014 7:03 AM
You can also use a Bluetooth 30 pin adapter, like this:
http://www.unotec.es/product.php?id_product=168
Beovision 10-46, Beocenter 1, Beo 4, Beocom 4, Beolit 12, Beosound 4, Beosound Essence, Beolab 6000
Des
North West, Engalnd
Posts 5
Des replied on Sun, Jan 5 2014 7:18 AM
Thank you for your help. I will check this out.
R
Des
Des
North West, Engalnd
Posts 5
Des replied on Sun, Jan 5 2014 7:21 AM
Hi Vermeer,
The Bluetooth 30 pin adaptor looks too good to be true. The short video on their website is very good. Do you have any personal experience or anecdotes with this product? If it is as good and simple as it looks it makes one wonder why anyone would swap a BS8 for an A8 with the attendant cost involved.
r
des
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Jan 5 2014 8:07 AM
Hi Des,
you have to consider that sound quality with bluetooth streaming is not very good, WLAN streaming is much better. Bluetooth is good enough in cars, but not at home. Another point is that bluetooth works only with short distances.
But probably it's worth a try.
Greetings
Räuber
Millemissen
Flensborg, Denmark
Posts 14,680
@Räuber
For 160 kbps files it should do well Big Smile
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Jan 5 2014 10:54 AM
Millemissen:
@Räuber
One point for you, dear MM!
But few years ago I connected a bluetooth receiver to my BS 9000. Sound quality was like 10 kbps, easy to hear with a 'hearing damage'!😉
Greets
Räuber
Amazone
Netherlands
Posts 187
Amazone replied on Sun, Jan 5 2014 3:48 PM
Re airfoil speakers touch.
Currently testing this but it doesn't seem to work streaming from an ios device, just from a computer with airfoil installed. Is this correct?
that would make it far less useable.
regards Joost
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
symmes
Posts 247
symmes replied on Sun, Jan 5 2014 6:04 PM
Amazone:
regards Joost
Then extend your wireless network with and airport express, connect airport express audio out to BS8 using a 3.5 to male RCA cable.  Using ios or itunes, distribute music via airplay.  Total cost, about $115 US.
Veermer
Murcia, Spain
Posts 49
Veermer replied on Mon, Jan 6 2014 8:29 AM
This 30 pin adapter is compatible with AirPlay, dlna and wifi:
http://www.dolry.com
Page 1 of 1 (12 items) | RSS
