How to replace/repair loudspeaker covering on beocenter 1 (or beovision 1)
Kakue
Posts 5
Kakue Posted: Mon, May 7 2012 8:44 PM
Hello dear forum,
I have a beocenter 1 in black with some scratches on the loudspeaker covering.
Do you think, that it is possible to replace the covering?
Thank your for your advice!
PS: It is more than likely that this question has been asked more than once. Unfortunately, I think I did not find the right words for searching.
Steffen
Denmark
Posts 1,408
Steffen replied on Mon, May 7 2012 11:45 PM
You carefully pull out in each corner -and then pull it downwards. But be carefull as some of the small plastic pins may break off.
But even with one or two pins off, it will still stay in place when you put it back.
Page 1 of 1 (2 items) | RSS
