Problem seems to have just started today. Signal is strong from an outside aerial, no hiss to sound but it's drifting from Stereo to Mono and back again every minute or so.....
Anyone ever had this problem?
Cheers
Nigel
Whenever I've seen it, it was signal strength-related. Try repositioning the antenna if possible, and check to see if it does it on other stronger stations. Maybe the station you usually listen to has temporarily reduced power.
