Is there a limit on how many BeoPlay A9's you can have on a network?
Would running a ethernet cable instead of using wireless work better?
ChadPetersen: Hi, Is there a limit on how many BeoPlay A9's you can have on a network? Would running a ethernet cable instead of using wireless work better?
not sure
also not sure what configuration you are contemplating, but did you know that you can not use two A9s as a stereo pair ?
BeoNut since '75
ChadPetersen: Would running a ethernet cable instead of using wireless work better?
I tried that with the PlayMaker (the A9 has a PlayMaker built in to it) and it was actually better using wireless, but configuring your A9 so it uses a fixed IP address, which never changes. This dramatically reduces dropouts.
Yes i did know you couldn't use 2 A9's as a stereo system
