Hi, I currently have a BeoCentre 6-26 HD + BeoLab 2 (2007) and am considering changing both for a BeoVision 7-32 Mk2 with Freeview module and 7.1 speaker.
Could anybody let me know will I see an improvement on the display? Currently i've a standard Sky box connected by a high quality scart cable and a MacMini connected via high quality cables for HD content. I'm aiming to keep the same connections.
Thanks in advance, Andrew.
In my personal opinion, due to the BeoCenter 6 having a smaller screen - I think you'll get a better image on the BeoCenter 6 HD.
I've also never really been blown away by the BV7-32 Mk1 and Mk2. The Mk3 was a lot better.
Lee
9 LEE: In my personal opinion, due to the BeoCenter 6 having a smaller screen - I think you'll get a better image on the BeoCenter 6 HD. I've also never really been blown away by the BV7-32 Mk1 and Mk2. The Mk3 was a lot better.
I agree. My BV7-32 wasn't even good, never mind great. I had a BC6 in the past and was impressed with the screen, the build and the TV.
Have you considered a BV10-32 (if you can find one)? You get a great TV, superb picture (arguably my BV10-32 Jan 2013 model has a better picture than my BV11) and you get Freeview HD built in to the set.
That is one of the things that amazed me, the resolution is no better on the 32 than the 26. Which I find odd. I'm not really a fan of the styling of the BoeVision 8, to be honest the current crop of B&O tv's would look a little odd in my house, imho.
My problem is the 26 is just a little small, my computer has a bigger screen.!! Hence looking at the 32.
Are there problems with the build quality??
Does anybody know where I could get the official spec sheets for both the 7-32 Mk2 and Mk3?
All the ones I can find online are conflicting. One site saying a contrast ratio of 3000:1 and another saying 1200:1 for the Mk3. My current 6-26 has a ratio of 800:1 and from what I can see the 7-32 Mk2 has a ratio of 1000:1. Will I notice that difference on the Mk2?
Well a trip to B&O Glasgow and now have a deposit down on a MK3 BeoVision 7-32. :-)
