App BeoRemote vs. BeoLink
This post has 1 Reply | 2 Followers
Hermann_
Posts 52
Hermann_ Posted: Fri, Jan 17 2014 10:04 AM
Hi
I have two BV 11 with various other devices, also an MLGW and ML / NL converter in use.
The BV11-46 I have configured WITHOUT power saving function
The BV11-40 I have configured WITH power saving function.
With the App BeoLink I can control all my B&O devices, also I have some macros that work perfectly. In addition, the home system is connected and integrated in BeoLink App, everything works perfectly.
But, If the BV11-40 was put into a power saving mode, I can it not turn on with the app BeoLink. With the app BeoRemote can I turn on him at any time (but I do not like this App, even I can't control the house system)
Can you give me a hint what I have to do for using the BeoLink app also when BV 11 is in power saving mode? The corresponding BV configuration I have already made​​, otherwise the BeoRemote via Wake on LAN would not work.
Thanks and regards, Hermann
BeoMegaMan
Posts 601
BeoMegaMan replied on Fri, Jan 17 2014 12:49 PM
Take it out of power saving mode and it will respond to your LAN commands via MLGW. No way around it.
Ah, you know... A little B&O here, a little there
Page 1 of 1 (2 items) | RSS
