Dear Fellow B&O's
Does anyone know how to program a button on Beo5 for XBMC, which would start XBMC on an ATV ?
Thanks a lot for your help.
Trolle
In the main menu of the ATV, my XBMC-icon is on the 2nd row on the left side. To select it I have to go one step down and select it.
Is that what you want to do? Program a button that goes one step down and GO?
Hi DoubleU,
You are right, this was exactly what I wanted to do. Probably a stupid question, but your answer was very valuable for me.
