Some advice please
This post has 8 Replies | 0 Followers
Nick
Nottingham
Posts 785
Nick Posted: Fri, Sep 7 2012 8:00 AM
Hi all,
  I have bought a bv7 with a faulty dvd player. I am going to save up to fix the drive, in the meantime do I buy a dvd1 or another brand to get on with?  I am asking this because if the dvd1 doesnt work correctly with the bv7 having a built in dvd player then i am wasting my cash.  Also are the dvd1's getting on a bit so reliability could be an issue?
your thoughts please
Thanks Nick
Peter
Earsdon
Posts 11,991
Peter replied on Fri, Sep 7 2012 8:22 AM
I would get a cheap other brand - you can probably get a Blu-ray player for less than a DVD1. Get the right one and you can probably work it using a PUC.
Peter
Nick
Nottingham
Posts 785
Nick replied on Fri, Sep 7 2012 9:03 AM
Thank you Peter, I do want to get my internal one fixed at some point. I did think about blu ray players, i need to work out how to connect it to the bv7 as the sky box is using the dvi socket.
Cheers Nick
DrDimitris
Greece
Posts 699
You can use this:
http://www.buy.com/prod/3-port-hdmi-switch-splitter-for-hdtv-1080p-1-3/216544962.html
On the dvi port of the BV plug this:
http://www.visionhd.ca/index.php?main_page=product_info&cPath=41&products_id=116
Done.
Dimitris-
Nick
Nottingham
Posts 785
Nick replied on Fri, Sep 7 2012 10:49 AM
thanks for that, do they work well?
2012martin
Posts 202
Will the hdmi splitter work with beo 4?
2012martin
Posts 202
Check your inbox mate
Nick
Nottingham
Posts 785
Nick replied on Fri, Sep 7 2012 2:14 PM
thank Martin, replied to
DrDimitris
Greece
Posts 699
No, unfortunately no. I use it as a cheap solution for my BV7, You select one of the 3 ports (for me new ATV, HD set top box, BR player), manually via a button. Piece of cake. (and on budget!)
Dimitris-
Page 1 of 1 (9 items) | RSS
