Is anybody using this setup to connect a 2300 (without master link) to an existing master link setup? And does it work ok?
Thanks, Andrew.
It will work fine. I have used one to connect a 2300 to Beolab 3500 link speaker.
Regards Graham
How does that work with both being IR receivers? That's nearly exactly the setup i'm wanting.
Place one of the components in option 0 so it does not duplicate the remote commands
