Hello
I just moved my beovision from the stand and replace it.
It doesn't power on anymore.The led on the top isn't red.
I have done nothing but move it on the floor 1 hour or 2 and replace it.
No chock or damage.
The power supply seems to work because the stand is plug on the output and everything is ok on the stand.
According to you, what could be the problem ?
The tv worked perfectly before this operation.
OLIVIER
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Hi Olivier,
The AV-9000 was never brought to our market, so I am just guessing here. I note that some of the Mains/AC power connections are laid out in a different manner on the BeoVision 7/BeoLab7-x systems where power goes to the speaker first, and then 'daisy-chains' up to the TV. Is it possible that this is true for the AV-9000? If so then perhaps the connecting mains cable is loose at the other end. Keep us up to date.
Russ
We kid because we love.
