Hi!
Bought a Beosound century a couple of days ago, the CD worked fine but I tried to fix another problem and broke the internal cabel between the cd and circuit board behind. Is this a part possible to replace and do anyone have an idea on were to buy it?
The problem I was trying to fix was that the cd door dont open when you push load and it seams as small arm is missing between the lock and the opening mechanism.
It bought it cheap and can still use it with my computer and the radio but would like to get it back togheter, have a friend that is reelly good in soldering so I could ask him for help with replacing the flat cable if I could find a new one.
BR
Lars
