Hi, I'd appreciate a little help with my aunt's Beovision 7-32 mark 2.
I've just replaced her Humax 9300t with a 5000 FVP recorder so she has access to catchup tv. The 9300 was connected via a scart lead, a problem with the 5000 since it only has hdmi output - no scart. I wanted to leave the switch on sequence the same since she's used to it and she's 86. I've used an hdmi - scart converter which works fine except for the picture format, the picture being too small. The Humax is set to 16/9 format but the tv isn't auto setting to that. Manual format works fine but is lost when the tv is switched off.
Is this to do with a lack of signal on scart pin 8 as I read about somewhere?
