Beovision 7-40 mk1 xbox one audio connection
dreamer
Posts 2
dreamer Posted: Sun, Feb 2 2014 3:08 PM
Hello,
someone help me please, I have a old 7-40 with only dvi input.I have buy a xbox one for my child, for video I buy a dvi-hdmi adaptor, the problem is the audio,the xbox one have a optical digital audio out and the 7-40 only coaxial in(right?) if in not mistaken.I have buy a adapter to convert the signal to digital o coaxial but i don't  understand where config the audio out form 7-40.Sorry for my bad english
Mark
London
Posts 1,063
Mark replied on Sun, Feb 2 2014 6:51 PM
Apple TV also has an optical outlet for sound. I connected the optical outlet via a TOSLINK cable to a LINDY SPDIF splitter (converts digital signal to analogue) and then L & R phono cable from this splitter to the AV4 connection on my MKIII TV (if you remove the rear panel that hides the connections their is a legend that shows you the placement of all the connectors).
I then went into TV SETUP, then OPTIONS, then CONNECTIONS, then AV4. Set source as PC, leave AUDIO and IR SOCKET to NONE and HDTV to DVI-I. I then added PC to my BEO4 remote which then allows me to quick access.
Hopes this helps Smile
dreamer
Posts 2
dreamer replied on Wed, Feb 5 2014 1:26 PM
Thanks for reply,
but I want know if possible use a coaxial audio, I have buy a spidf to coaxial.
Page 1 of 1 (3 items) | RSS
