Problems and mistakes of my bv 11
This post has 5 Replies | 3 Followers
manitou
germany
Posts 61
manitou Posted: Sun, Feb 9 2014 4:59 PM
Since beginning my bv 11 has problems.
Most of the errors occur in Web Media:
1. Entered passwords keep disappearing . Sometime they keep 3-4 days, and sometimes only hours .
2. ( Press and holding long) the Back button leads to the message: no network , instead of jumping back to the app homepage.
3. The Back button (pressed briefly) is working analog to back double-arrow button .
4. If you come from an app back to the app homepage, then the tv freezes.
5. The white background of html pages are in 98 % of the views black ( eg. Google search results page , eBay detail page ... ).
The following error exists in Radio:
1. The stations can not be selected with the number buttons on the Beo 4 . The previously selected station just plays on. Only with arrow up and down, or the station overview I can select the radiostation.
And ... tv:
1. When an encrypted channel is recording, it can happen that you can not select unencrypted channels ( depending on which internal tuner he chooses to record)
So these are now only the fiercest mistakes.
At b + o they are not really able to help me. System 4 has already been replaced. Struer does not answer.
Some of the error do not appear at dealer tv 's, but some do .
Have you any idea what all this can be?
Do you have the same problems, or does your bv 11 run properly?
Best regards, annoyed , horst
Flappo
Posts 850
Flappo replied on Sun, Feb 9 2014 5:17 PM
i'd plug a pc or mac mini in if you want to do net stuff seriously on this tv
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Sun, Feb 9 2014 6:38 PM
I have your problems 2 and 4.
Luckily (for me) I don't use webmedia at all.
Let's hope there is an update soon.
Chris Townsend
Qatar
Posts 3,531
My screen turns off with curtains and all, but the sound staysErm.. For no reason(I'm not sat on the controller)
This is not only detracts from the obvious picture viewing enjoyment, but the large build up of dust behind the screen is now visible.
Flappo
Posts 850
Flappo replied on Sun, Feb 9 2014 7:44 PM
i'm worried about the dust build up , but my avant had it too
i guess that's hand built for ya !
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
Often need to go back to TV and then re-enter webmedia to get rid of the No Network message. Spotify and YouTube work from the main menu even when there is a No network message and no access to the webmedia homepage.
No sign of any dust, but according to another thread it can be dealt with by undoing 4 screws.
Graham
Page 1 of 1 (6 items) | RSS
