My Beo6 staretd up as normal after configuration, and showed the "scene" menu.
After just a while it went all black, and do not react at all.
Any tips?
Charge it for one day and then reconfigure it. I had this problem before and even if you do not see anything on the screen the Beo6 is not dead (at least mine wasn't). Maybe it helps...?
