Problems with Beocenter 9500
This post has 12 Replies | 1 Follower
Pasi_F
Posts 3
Pasi_F Posted: Thu, Jul 30 2015 11:18 AM
Hi everyone, i owned beocenter a couple of years and worked great..
After yesterday when i was hiding cables, after that i wanted to listen some cds. Cd door was jamming, also cassette door stucked about halfway opening. I watched internet and found similiar problems. Downloaded repair manual and here goes my problem:
I want to lift cover up (unscrewed all 9 screws) when i try to pull the cover there`s  two purple wires that tight so the cover wont lift up. They are located near cd-bay and screen up right. Anyone any ideas what to do?
P.S sorry about my bad english, try to understand text and ask if you didnt get the problem :)
-Pasi
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Thu, Jul 30 2015 3:17 PM
Opening the BC9500 works like a carhood. Remove three screws at the front and the ones located at the rear upper part. Then opening by lifting the back part. Hinges are at the front. Remove CD and Cassette and make sure that the lids are closed. ALso important when closing.
Orava
Finland
Posts 991
Orava replied on Fri, Jul 31 2015 1:41 PM
And be carefully with glasspanels, they tend to get loose over years and drop off.
Pasi_F
Posts 3
Pasi_F replied on Sun, Aug 2 2015 4:38 PM
Got the cover up and everything seems to be ok on wires and lifting system. I think door motors dont get enough power. Checked the fuse F2 which controls motors and thats working. Could possibly broken diode (D2) be the problem?
Pasi_F
Posts 3
Pasi_F replied on Mon, Aug 3 2015 10:59 AM
i also took video for the problem: https://youtu.be/S0XJk54-dOI
Weebyx
Denmark
Posts 1,213
Weebyx replied on Mon, Aug 3 2015 12:53 PM
Pasi_F:
Are you sure it is not just dust and old lubrication, in according with bad rubber bands ?
If you pull off the glaspanels(be careful), then you can find 4 screws that hold the middle mirror part, it lifts right off, and then you have access to the guides for the lids, try to clean them very good, and use a small cue-tip with solicone to lubricate it all. Take a look at the rubber bands from the motor, and see if they slip...
CAUTION: When removing the glass (one screw at the top left, and one screw at the bottom left of the unit, then slide the glasspanels to the right), be very careful, and anticipate that the class will come loose from the plastic holders.
If they come loose, clean both the glass and plastic with benzine, just give it a good soaking and let sit for a while, then rub the old tape off under warm water.. NO SCRAPING with any kind of tool !!!
Then use some good glue in small amounts along the glass all around, and glue it on. You also might be able to find som automotive tape that holds the letters on cars, it should also work, but the key is to clean it good before glueing or taping again.
/Weebyx
Orava
Finland
Posts 991
Orava replied on Mon, Aug 17 2015 1:06 PM
Those strings should be cleaned also, they slip as well
Beobuddy
Posts 3,972
Beobuddy replied on Tue, Aug 18 2015 11:32 AM
...or replaced by new cord.
Often I have cleaned and lubricated these systems, but sometimes to no avail.
The culpritt is burned contacts inside the motor(s). As it has to work to hard during the last years, that's the result. It doesn't have enough torque to open or close the lids. Cleaning these contacts inside the motor(s) or replace them by new one(s) is the solution.
But only if all the other former named possible causes are looked after.
Garten
Sweden
Posts 72
Garten replied on Thu, Jan 21 2016 12:54 PM
Is it possible to actually open the motor and clean the contacts.. I have a new motor for my CD door coming, but would be good to know if a motor in this way can be made to regain its torque?
BM 2000 *1974, 2x BM 1200, BM 1001, BG 1200, BG CD X, BC9500,BM3300,Bcord 3300, BG CD3300, Beovox Cona, Beovox CX100, Beovox 1200, Beovox RL60.2
Garten
Sweden
Posts 72
Orava
Finland
Posts 991
Orava replied on Fri, Jan 22 2016 8:37 AM
They can be opened, cleaned and relubricated, although they arent ment to be serviced.
Garten
Sweden
Posts 72
Garten replied on Sat, Jan 23 2016 8:04 PM
Thanks, assume access is through the plastic bottom, bending the small metal tabs outwards and just pulling of the beige plastic over the solder pins?
Orava
Finland
Posts 991
Orava replied on Sun, Jan 24 2016 10:36 AM
Yes but solder pins raises with cover and brushes, I think...
Page 1 of 1 (13 items) | RSS
