Bel vision 4 screen calibration
Moorsight
Posts 2
Moorsight Posted: Tue, Mar 17 2015 8:34 PM
hi. I have a beosystem connected to a 50 inch beovision 4 with camera fitted for calibration. every time I turn in I get the message  "screen not measured contacted your dealer or installer"  the message goes after a short time. If I go into the menus the option to do a manual calibration is not available    Its greyed out . Apart from contacting a dealer any other suggestions?
tompa
Posts 64
tompa replied on Sat, Mar 21 2015 10:29 AM
You not telling what beosystem you have...? but i assume that it's beosystem 4 and then you have to call b&o shop to get a technican out for calibration with servicecamera connected to beosystem 4
Moorsight
Posts 2
Moorsight replied on Sat, Mar 21 2015 11:45 AM
Hi yes its a beosystem 4. ok Ill contact B&o thanks for the info just wanted to check there was nothing obvious I was missing before I called them.
Page 1 of 1 (3 items) | RSS
