Beosound 5 encore with beovox 2.2 speakers
This post has 5 Replies | 2 Followers
Paul cheacker
Spain
Posts 130
Paul cheacker Posted: Fri, Feb 21 2014 11:37 AM
Can I run something by you experts, someone told me that I could connect the beovox 2.2 passive speakers to the beosound 5 encore using a ML-MCL convertor using the power link cable from the BS5E. Is this correct?
Current b and o Products
beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
Millemissen
Flensborg, Denmark
Posts 14,680
Hi applemac1,
you can run any passive speaker(s), if you use the ML/MCL converter as an amp.
Just connect the PL-out of the Encore to the PL-in on the converter with a MK2 PL cable.
You will need speakers cables with a 2-pin din plug at one end and (in case of the BeoVox 2.2) bare wire at the other.
Greetings Millemissen
Paul cheacker
Spain
Posts 130
Thanks millemissen, one last thing I am looking for the ml mcl ebay and wanted to ask will all the mc mcl work what I mean is I notice that there are different marks eg mark 1 etc
Millemissen
Flensborg, Denmark
Posts 14,680
The ML/MCL Converter is built on the older MCL2P (first one is from 1985), which was used in linkrooms with the MCL2AV kit.
It is the same unit as the BeoLink Passive, which comes with the ir-eye as well (for ML-linkrooms).
You can use either of those - because you 'only' need the amp-part of it.
I would go for the youngest of them - look for the two first  digits in the serial number.
Starting, if I remember right, with 01=1986, 02=87 and so on..
There are differnt SW versions - but that should make no difference, if you only use it as an amp.
Paul cheacker
Spain
Posts 130
Millemissen , thanks very much.
Paul cheacker
Spain
Posts 130
Page 1 of 1 (6 items) | RSS
