Hi there,
After some advice on this forum I'm close to purchasing some B&O vintage equipment.
I have a basic question relating to S45 stands.
I've sourced some "new" Beovox S45 stands. Will these stands fit on Beovox S45-2?
Many thanks,
H
I am pretty sure they will. However they are, I believe, higher
Peter
Hello,
I am looking for a set of stands for my B&O S45 speakers.
Can you please give me the source of where you purchased your stands?
Thanks in advance,
Steve
Note that the type 6017 stands for Beovox S45 (type 6427) will fit Beovox S45.2 (type 6312) which normallysits on type 6013 stands and vice versa - but the height is incorrect as Peter suggests.None of them will fit the Beovox S45 (type 6302) since these speakers have a composite back withoutthe threaded holes needed for the stands.
