Hi all:
As you maybe aware I had a Beovision AV9000 which was working then the tube died. I have now sourced a screen only which I hope I can just transplant onto the base of the broken TV.
My question is, is this possible or are these TVs paired with their bases and as such the parts cannot be interchanged?
Graham
I did this before with success.
But no idea if this will work always (software versions etc.)
Give i a try!
Ralf
Hi Ralf:
If it throws a software error do you know of a way to fix this or is this an open the TV up kind of job to flash new software?
Sorry, no idea.
I believe it will work for you, too.
Thanks - will probably give it a go. Just don't want to end up with two broken/not working TVs in the house - they are pretty big.
The AV9000 is based on the MX7000.
Tubes can ge placed with the same numbers on the back of the tube.
Software can't be flashed. It's an hardware version. But not needed.
Hi:
Thanks, I am not planning on replacing the tube - I just want to place a complete TV unit (the blue bit) onto my speaker base. Is that possible?
