Hi
I am looking for a new switch to my Master Control Panel 5500..
Does anyone know were to get one?
I live in Sweden.
Best Regards
Which type of switch you search?
Is something like that:
http://ee.rsdelivers.com/product/marquardt/10100101/micro-switch-spdt-ag-sp-lever-solder-tag/7410928.aspx
Best regards,
Aleksei
By taking the switch out of the panel, it is repairable. Probably black contacts. Just cleaning is enough.
Clean the eye that looks at the rotations of the wheel.
It is also possible that it's ldr that senses the led's lightbeam is broken. have to think a bit more about it, as I replaced that particular part some weeks ago with the help of a donor.
